Preserving LED alert
Is there a setting or configuration that allows the LED notification to be kept?
For example, when I enable the alarm on my house, all of my Red switches alert with a red chase LED. However, if the switch is turned on or off the alert is lost and goes back to the default set by the switch. Is this controlled via the driver or firmware?
@funzie - You’ll need to upgrade your switches to the latest beta firmware to fix the notifications to stay on when switch is powered on/off.
Thanks, I’ll give that a try. I skimmed through the firmware changelog and nothing popped out related to that.
I’m assuming it’s this change:
Notifications no longer turning off when user adjusts the level or performs various other actions on the switch.
@funzie - Correct.
