Question About Smart Bulbs, Groups, and Binding
I have 3 Innr Smart Bulbs and a On/Off. The On/Off load is connected to a smart fan so the relay just needs to be on all of the time.
Current Config:
Group A - Bulbs 1 to 3, On/Off Endpoint 1
On/Off Endpoint 2 → Group A
On/Off Settings Defaults EXCEPT Smart Bulb Enabled and set to “Dimmer” mode.
My goal is to have the switch control the lights with dimming, but have the LED bar represent the level. I would like to be able to have the lights be able to be turned off individually and the LED bar should be off if ALL lights are off, but on if ANY of them is on. (and I guess set to the level of the brightest)
Everything works fine unless I manually tun off the lights manually. The group state shows up correctly (when the last light turns off the group shows as off), but the LED bar doesn’t follow. It just stays on.
I have tried also binding On/Off EP1 to the group… that didn’t change it.
Is there a solution to this?
