# Red Series mmWave Firmware Changelog | VZW32-SN
**URL:** <https://community.inovelli.com/t/red-series-mmwave-firmware-changelog-vzw32-sn/20921>\
**Category:** Firmware Development & Changelogs\
**Created:** [February 4, 2026, 7:30am UTC](https://community.inovelli.com/t/red-series-mmwave-firmware-changelog-vzw32-sn/20921 "2026-02-04T07:30:10Z")\
**Posts on this page:** 1\
**Showing post:** 1
<div class="post-metadata">
**Author:** ![EricM\_Inovelli](https://community.inovelli.com/user_avatar/community.inovelli.com/ericm_inovelli/32/517_2.png) [@EricM\_Inovelli](https://community.inovelli.com/u/EricM_Inovelli)\
**Post date:** [February 4, 2026, 7:30am UTC](https://community.inovelli.com/t/red-series-mmwave-firmware-changelog-vzw32-sn/20921/1 "2026-02-04T07:30:10Z")
</div>
**September 2, 2026 / v2.04**
Beta Testing Available Upon Request
**Changes:**
**Note: 2.04 has disabled P116 reporting by default. This means the “person in the Reporting Area (Read Only)” will not update by default. The reason is that this report is the same as the “motion” notification and creates extra packets on the network every few seconds. It can be re-enabled by setting parameter 107=2, but I believe it would be better to create any automations based off of “motion” instead.**
- Updated **P107 (mmWave Report Bit Mask)**:
**Bit 1:** Reports mmWave target information.
**Bit 2:** Reports P116.
- Fixed an issue where the P20 could not restore its default settings.
- Changed the default value of P50 (Button Delay) to 3.
- Optimized the network re-connection logic.
- Further optimized the interaction logic between the mmWave module and the Z-Wave chip.
- Optimized the processing logic of the metering module.
**June 17, 2026 / v2.03**
**Changes:**
- Optimized the response speed of the switch buttons.
- Fixed color distortion affecting some colors at low brightness.
- Fixed some situations where the energy is reported incorrectly.
- Optimized the quick-start process logic (specifically when Ramp Rate \> 0).
- Fixed an issue that prevented some mmWave module parameters from being configured.
- Updated the definition of P107 (mmWave Report Bitmask): Bit 1 enables mmWave target information reporting, and Bit 2 enables P116 reporting.
**April 11, 2026 / v2.02**
Beta Testing Available: [https://files.inovelli.com/firmware/VZW32-SN/Beta/2.02/VZW32-SN\_2.02.gbl](https://files.inovelli.com/firmware/VZW32-SN/Beta/2.02/VZW32-SN_2.02.gbl)
**Changes:**
- Optimized the interaction logic between the switch and the mmwave module
- Fixed the incorrect use of duration in the SwitchMultilevel Set
- When the switch is restarted, P240 will be reported, which serves to inform that the switch has been restarted before.
**February 3, 2026 / v2.01**
**Changes:**
- Fixed a situation where P101~P106 could not be configured correctly
- Fixed the issue where meter energy would continue to increase even when the load was set to “Off”.
_[View the full topic](https://community.inovelli.com/t/red-series-mmwave-firmware-changelog-vzw32-sn/20921)._
