Setting the parameter for non neutral
i have installed lzw31 with no neutral - while it works - i see i need to set the parameter - I am using a vera hub so i cannot do it at the Hub - the instructions say 1 0r 0 - but i don’t understand from the document how to tell what it is set at - or change it.
I don’t think you can query at the switch to determine the settings, but this will show you how to set them. Presuming you’re referring to a 3-way with an Aux.
EDIT: Yeah, I know. It’s an old post. So much for “Latest” sorting properly . . .
