SmartThings Edge Drivers: LZW30-SN, LZW30, LZW31-SN, LZW31, LZW36, LZW41, LZW42, LZW45, LZW60, VZM31-SN, NZW30, NZW31
Can you share a screenshot of the driver page in the ST app? The page that shows the driver date, etc.?
I assume you meant the inovelli driver?
Actually meant the default driver that creates the child devices. I would like to see it in action.
My bad! Here you go!
Sometimes it doesn’t do it right away, I just readded one, and i had to switch it back to the inovelli driver, and used it for a second, then when i switched it back to the zwave switch, the devices were created.
Typically when you make a change in a device driver / settings, if you go back to the Devices page, then select the device again, you should see the change take effect.
Known issue with the iOS app. You only see the main component in THEN actions.
Well that’s frustrating. Wish there was a place that tracked outstanding issues.
thanks for the heads up though!
@EricM_Inovelli @Eric_Inovelli I am having the same issue with the fan module, I’ve created the virtual dimmers and set the smart lighting to mirror. When I turn the Main Switch on it turns both the fan and light on and updates the virtual switches but selecting the virtual switched on doesnt control the devices. I am unable to use a routine to test this as the isn’t an option for the channels I see only the main. I am also seeing a rather long delay in the light turning off after pressing the physical button (about 10-15 seconds).
I am guessing still no way to update the Blue’s firmware on Smartthings? I haven’t heard anything new on their forums
I don’t think it’s available yet (or if/when).
Lately my Black dimmer on the edge driver has been somewhat unstable. It will go offline in Smartthings, but somehow even when it shows offline it will take commands with a long delay. Alexa control will stop working in this state.
I’m pushing an update to the LZW36 driver that has 3 options in the device settings:
  1. Create Light Child Device
    This will create a child device for the light endpoint.
  2. Create Fan Child Device
    This will create a child device for the fan endpoint.
  3. Disable Root Endpoint Control
    Make it so that the main switch does not control both the fan and light at the same time. Useful if you want to only use the child devices for control. Helpful if you use voice control and don’t want the main device to be controlled along with the child devices.
I’ve been testing for a lot of the day and everything seems to be working for me, but let me know if there are any issues. It might take a few hours to show up for you.
So excited to see this. I tried the method @Jamesonrw suggested and it did create the child devices for me as well. The Z Wave Switch from Smartthings now has the Version “2023-05-09T18:33:45.26072198”. Inovelli Driver shows 2022-10-04. I wonder how long updates take to hit the hub and if there are any ways to speed up hub to check.
Update.
I was curious so I updated my Fan+Light devices to SmartThings Driver, it created the child devices. I then uninstalled/reinstalled the Inovelli driver from the invitation page. That pushed the newest version of the driver down to my hub.
I changed my devices from the SmartThings driver to Inovelli, this worked but my fan had a dimmer slider unlike @EricM_Inovelli screenshot. I removed the child devices and enabled the “Seperate Control” in the settings of the device and it created two new child items with the proper slider and logos.
Ok, so sounds like positive results. I guess if you have used the SmartThings driver that created child devices you have to delete them to make the Inovelli driver work.
@pmjoen @Jamesonrw @danny.pena
Just a notification that our LZW36 driver has child device support now. If you have a working setup already there is no need to change it, but in case you are still having problems.
SmartThings Edge Drivers: LZW30-SN, LZW30, LZW31-SN, LZW31, LZW36, LZW41, LZW42, LZW45, LZW60, VZM31-SN, NZW30, NZW31 - So Hot Right Now - Inovelli Community
Thank you so much for updating this Edge Driver. I’ve updated my 4 Fan+Light switches and they seem to be working properly.
