ST Automation possibilities?
Has anyone found a way to use the energy reading of the LZW 30 to cause an automation in ST to occur?
Background: I’m trying to work around the on/off switch losing power when the relay is bypassed. Switch will correctly report 0W when it turns itself off. Won’t report to ST that it is actually off. But the led on the switch shows it has been turned off even though it has been bypassed to prevent this from happening. This only occurs when the smart lights the switches are controlling are off.
So I want an automation that tells the switch to turn off then on again which would restore power to the smart lights again.
Hope that makes sense. I have a feeling ST cannot pole these settings without a custom SmartApp. I think Hubitat could probably do it.
Cheers.
