I wired it to match the diagram (I think), It worked, connected to ST, all is good. After an hour I went to check it again and nothing. Lights didnt work, not responsive on ST app, and no LED color on switch. I pushed all the buttons, reset the breaker but nothing brought it back.
A friend said to try swapping the black wires (Line/Load). I tried this and the switch LED turned on, ST app able to control switch LED, but lights dont work.
When I set AC Power Type: Neutral and Switch Type: 3-Way Toggle there is a clicking noise coming from the switch. When I change it to AC Power Type: Non Neutral and Switch Type: 3-Way Momentary there isnt any clicking. Both still have no lights turning on.
Any other info I could provide to help get a solution?
I did not replace a Zooz or Inovelli switch, there is however a dummy switch connected to a Inovelli switch in the box if that matters
This was actually a replacement for another defective switch. The first was actually defective as I replaced it with a spare and it worked. My gut tells me this one is not defective (I have installed over 20 inovelli switches), let me play with it a little more before you requesting a replacement. Would pictures of the wiring help?
Does it matter which side is the dummy and which is the Inovelli? Would swapping them help?
