Unable to get 3 Way with Neutral and Aux Working
I am replacing a Homeseer WD-100+ switch with an inovelli red dimmer, I already have WA-100+ aux switch installed, and nothing I do seems to get the inovelli red to work with the WA-100+ . The Aux switch works fine with the WD-100+, but not the Inovelli switch.
Update:
Got it to work, changing the device configuration setting in the Z-wave hub (Home Assistant) from Non-Neutral to Neutral, and from Load only to 3-Way it worked.
