Moving over to Hubitat and I’m adding a lot of new automation in the process. I have a 3 way light that I want to wire with a LZW31-SN on both ends. In reading the documentation it doesn’t sound like that you can have 2 of those on a 3 way but if you just wire one with no actual connection to the light and use it with an association to the other switch then it would behave the same as a 3 way with the same capability on both ends correct?
