White Series Dimmer — Single Pole, Neutral Connected, Light Always ON Despite Smart Bulb Mode Disabled
Model #: Inovelli White Series Smart Dimmer — VTM31-SN
Setup: Neutral Connected
Configuration: Single Pole
I’m experiencing nearly the exact same issue described in this thread:
Can’t Get White Dimmer to Work — Single Pole, Always On
The difference is that I’ve already disabled Smart Bulb Mode, and the problem persists.
The switch powers on, its blue LED indicator illuminates, and it successfully pairs with Apple Home. However, the connected ceiling light fixture remains ON regardless of whether I use the physical paddle or turn it OFF through Apple Home.
The wiring follows Inovelli’s Single Pole, Neutral Wiring diagram.
  • LINE: Black conductor from constant-hot supply
    LOAD: Black conductor running directly to the ceiling fixture
    NEUTRAL: White pigtail from the neutral splice
    TRAVELER: Not connected
    GROUND: Connected
*The fixture’s white neutral is connected to the same neutral network as the switch
Here’s what I’ve done to troubleshoot the issue:
  1. Disabled Smart Bulb Mode.
  2. Configured the switch for ON/OFF operation rather than dimming.
  3. Confirmed the switch powers on with neutral connected.
  4. Successfully paired the switch with Apple Home.
  5. Attempted ON/OFF commands using both the physical paddle and Apple Home.
  6. Confirmed that Apple Home can report OFF while the physical fixture remains illuminated.
  7. Pulled the air-gap tab, which immediately turns the ceiling light fixture OFF. When the tab is pushed back in, the light receives power again and remains ON.
These are a few questions I’ve been trying to resolve:
  1. If Smart Bulb Mode is disabled, what else could cause the physical load to remain energized while Apple Home reports OFF?
  2. Is there another local configuration setting that could disable physical load switching?
  3. Is this Luxrite LED fixture compatible with the VTM31-SN?
    *Fixture: Luxrite 2.5" LED Cylinder, 15W, TRIAC / 0–10V Dual Dimming
  4. Are there any recommended diagnostic steps to distinguish a configuration issue from an incompatible fixture or defective switch?
I’d appreciate any guidance. I’ve spent considerable time troubleshooting this installation and would really like to resolve it soon.
Thank you in advance!
That’s a dual-capability light, so it SHOULD be compatible with forward phase (default) dimming. I’d double-check to ensure the low-voltage conductors are capped off in the ceiling box. If you just installed that light, then you’ll know, and you can disregard this. But I don’t really think that’s the issue.
Can you temporarily try the dimmer in another location with a fixture with a “regular,” i.e., non-low-voltage luminaire? I’m beginning to wonder if some of these switches are failing.
You can also factory reset the switch to ensure the SBM is truly turned off. The switch will come back up with SBM turned off.
Also, FWIW, can’t exactly tell from your switch picture, but if you are daisy–chaining your grounds, that’s not a good idea. It’s not prohibited by the NEC, but the conventional wisdom says to pigtail grounds to keep a failure from affecting anything downstream.
Thanks, Brian! I appreciate you taking the time to help troubleshoot this.
A few updates regarding your suggestions:
  1. Both pink/purple dimming conductors were individually capped in the ceiling box.
  2. I had factory reset the Inovelli at least twice during troubleshooting, so Smart Bulb Mode should have returned to its default disabled state.
  3. The neutrals were joined using pigtails rather than daisy-chained. I also noticed that I needed to complete the grounding pigtail arrangement at this switch.
  4. I tested the dimmer at another location with a different light fixture, and it behaved exactly the same way; the light remained ON and wouldn’t respond to the switch.
I believe we’ve resolved the issue, thanks to your suggestion to test the dimmer at another location.
After experiencing the exact same behavior with a different fixture, I swapped the original dimmer for a new White Series Dimmer. The replacement worked immediately, without any additional wiring or configuration changes.
It appears the original dimmer was defective.
Thanks again for pointing me in the right direction. I really appreciate your help!
Glad you got it resolved.
I fixed my typo above. I meant to say daisy-chaining grounds!
