White Series Scene Control in Home Assistant?
Hi,
I have several white series dimmers and primarily use HomeAssistant for automation(I do have HomeKit as well, but mostly just for controls via Siri on my HomePods). I went to try to set up scene control on the one in my bedroom to have a double press down turn off all the other lights in the house last night, but couldn’t seem to find any events around double-press at all to connect an automation to.
Poking around, I found the HomeKit instructions for doing this and was able to set that up, but would prefer to keep things in HA if possible. Wondering if there’s any way to manage this in HA(or plans to add it).
Have you installed the HA blueprint for multi-taps? It was named “Inovelli Matter Switch Tap Sequences” when I installed it a while ago…
Ah! I was completely unaware of this. Looks like that’ll work, thank you!
If you want some more details about how event triggering works in Home Assistant, you can also read the guide I posted here: Home · jvmahon/HomeAssistant-Tools Wiki · GitHub (just in case you don’t want to use the existing blueprints).
