Z-Wave 5-Button Scene Controller + Dimmer Switch | Project Limitless
Hey all,
There’s been an interesting development come in the last month or so in which our manufacturer came to us with an opportunity to develop a Z-Wave scene controller and we’ve officially kicked off a project with them. Project Rock Out.
NOTE: We’re still working on the remotes (BFF) and Fan (Windy City) – this one happens to be a special project with the manufacturer, so they’re passing this one through R&D quicker for us.
Project Team
Feel free to tag any of us with questions. Eric M is the go-to for any firmware related questions, myself or Courtney are the go-to for just about everything else in this project.
Introduction
As per our tradition of working with you amazing people, here’s what this thread allows us to do as a community.
  1. Allows us to keep everyone updated on the project status (either good or bad)
  2. Allows you to participate and help us develop amazing products together
  3. Enjoy each other’s company and have fun talking home automation
  1. Project Overview
  2. Initial Hardware & Software Requirements (edited to remain up-to-date)
  3. Timeline (edited to remain up-to-date)
  4. Pinned Ideas & Shout-outs (edited to remain up-to-date)
  5. Weekly Recap
Housekeeping
  • DATES & FUNCTIONS ARE NOT SET IN STONE: Just a reminder that all dates and functions are sometimes fluid. We have to make choices based on feasibility, opportunity costs, and overall timeline. I will be as transparent as possible on these decisions, but just a heads up, they may not always be exciting.
  • NO IDEA IS A BAD IDEA: Ok, some are, but honestly throw out anything that you can think of. If we use your idea, we’ll credit you and send you a free device, so take that shot!
  • VERSION 1 VS VERSION 2: Some ideas may be fantastic, but may not make the cut for the first version of the product. Once the product is locked in from a function standpoint, we’ll keep a tally of V2 ideas and then once the product is produced, we’ll move the ideas over to the Suggestions & Wishlist section.
Project Overview
The purpose of this project is to give people more of what they’ve been waiting for. This has been something that we’ve wanted to produce for a while and has been requested a ton from the Z-Wave Community. So, with the manufacturer coming to us with an opportunity to co-develop something with them, we’re excited to bring to market a Z-Wave Scene Controller Dimmer Switch.
Project Name - Rock Out Limitless
Nathan can give you the reason why he chose this name! I was never a fan of the name Rock Out and wasn’t sure why it was chosen, so we’re going to change the name to Limitless as it reminds me of the movie with Bradley Cooper (who is a national treasure) where a pill unlocks his mind. This project is similar in that it will unlock your smart home with all the scenes and functionality available.
Rock Out Limitless - Hardware Requirements
Here are the initial hardware asks we came up with. Pretty decent start!
Hardware - Initial Mockup
Hardware - 5-Button Scene Switch (Look / Feel)
  • Push Buttons (3-Scene Buttons, 2 Dimmer Buttons): Top 3 buttons will be able to activate scenes, bottom 2 buttons will turn your load on/off/dim (and will also have scene capability)
  • RGB LED Bars: There will be three (3) LED Bars that will show what scene is activated (on/off) and also show which specific scene has been activated (the LED Bar can change colors based on the scene)
  • Decals: TBD (we’re trying to figure this out) – the switch may come blank and then there will be an ability to send in for etching. Or maybe the default will have stickers and then you can purchase the etching separately. More to come.
  • Colors: dimmer switch will be offered in white, but the paddle should be able to be replaced to change colors (almond, light almond, brown, red, black, grey, etc)
  • 700 Series Z-Wave Plus: switch should be powered by Z-Wave
  • Z-Wave Long Range Feature: Z-Wave Alliance Announces New Z-Wave Long Range Specification - z-wavealliance
  • Power Monitoring: Should measure power consumption for load
  • Z-Wave Distance Estimator: LED lights will light up red if not in range, or green if in range
  • CFL & LED Compatibility
  • Max Wattage & Amperage: 500W (Incandescent) & 300W (LED/CFL) for bulbs
  • Neutral & Non-Neutral Compatibility: Switch should be able to work with a neutral or without
  • Multi-Switch (3, 4, 5-Way, etc) Compatibility: Should work as our current dimmer switches do in that they should work with either a dumb or aux switch
Rock Out Limitless - Software Requirements
Below is what we came up with for the software requirements. It’s going to be one insane switch!
  • Z-Wave Scene Control: 12 scenes (4x scenes per scene buttons) + Additional scenes for the bottom 2 buttons to set favorite levels (ie: 2x tap to set to 50%, 3x tap to 75%) – this can be disabled to create, “instant on”
  • Notifications via RGB Bars: RGBW Bars should be able to change colors based on events set up by customer (ie: if window sensor is opened, RGBW bar changes to red)
    • User can choose to sync the bars or have them show separate notifications
  • RGB Bars Config: bar should be able to change colors and also dimmed to the customers favorite level
  • Auto Timer: switch should have a timer that shuts the switch off after a certain amount of time
  • Easy Config: switch should be able to be configured via the switch. This will also have the ability to be locked (so it cannot be tampered with)
    • There should be infinite customization via parameters in the firmware, but also set customizations for HUB’s that do not allow parameter changes (ie: Wink)
  • Internal Relay Disable: internal relay should be able to be disabled locally and via Z-Wave
  • Set Min/Max Level: minimum dim level / maximum dim level (for lights & fan)
  • Ramp Rate Configuration: ability to change how fast/slow light turns on
  • Ramp rate & instant on/off separated
  • Default Dim Level (for lights): ability to set the default dim level
  • OTA Ready: ability to update firmware via OTA
  • Associations switch should be able to be associated to other Z-Wave devices
Timeline
Ah, everyone’s favorite part. When is this flippin thing going to be released? Great question – here’s the high-level of what happens leading up to the first release of the timeline:
1. We present a PRD (Project Request Document) that has all of the above info in it DONE
2. R&D (manufacturer) analyzes the PRD and we go back and forth until we can align on 90% of the product DONE
3. Initial Timeline is released and remaining 10% of product features are added/cut along the way = IN PROGRESS
Again, just want to throw this out there – I don’t have a crystal ball so I can’t predict things that come up along the way. Trust me when I say we’re trying our best to get things launched on time.
Update 1/4/2021 We’re targeting Q1 2021. We’re targeting June 2021 September 2021 to begin production. Expected delivery would be beginning of July October 2021.
Update 2/26/2021 ~~ Hey Guys! Exciting news. Progress is being made. Here are the 3D renders of the device. I ended up learning a bit about fan control and it’s requirements for this device. Long story short, if we go with fan control, we lose the no neutral capability. We opted for leaving no neutral capability in and are exploring the options for on/off fan control. TBD there. Things are progressing on the device we timeline still seems good! (Timeline is obviously fluid but if you have been with us, you know what that means! ha ha.) Here are some of the 3D renders if you want to check them out.
Also, we are looking into etching capabilities for the paddles. We know not everyone would want this but what we are thinking is the device would ship with blank white paddles except for the up and down. We would then get replacement paddles just like we do for the other switches in all colors and you would be able to customize what you wanted on there. We aren’t sure if it will be done in house or it will be outsourced and we aren’t sure of the cost at this time.
Don’t hesitate to ask any questions or add comments below.
5-Button Front
5-Button Side
Update 3/3/2021 ~ Hey Everyone! Exciting update.
  1. This switch will be able to control a fan on and off only. It will be neutral wire required for this to function. If you don’t have a neutral wire, it will not work to control the fan on/off.
  2. This device will not have the tabs on the sides! Excited about that.
  3. Some glossy 3d renders for you.
Update 04/28/2021 - We’ve switched responsibilities on this project and I (Eric H) will be leading this now. Today we approved the tooling to begin! If you’d like to see the approved AutoCAD design, feel free to check it out (it’s actually pretty cool to see how it all comes together): Fusion
Update 05/10/2021 - We should be receiving preliminary prototypes to approve for mass prototypes on Thursday, May 13, 2021. FedEx tracking # for anyone that’s interested: 773657658594
05/12/2021 - We received the switches early and messed with them a bit yesterday. They look and feel awesome (aside from the glow-in-the-dark material they used). The tactile click feels really good. We’re sending them off to our partners to see what they think, but from the team’s point of view, we’re ready to approve the beta production for testing!
@Courtney_Inovelli is accepting any hand-model positions.
05/11/2023 - I’ve updated throughout this thread, but I’ll start doing it here as well since this is a long thread. Right now this project is on hold, but we are exploring either crowdsourcing it like our mmWave switch or asking our B2B partner if they are interested in it. I will try to update the status monthly, even if it’s just a, “still on hold”.
I just wanted to say that from a firmware perspective, it’ll pretty much be a Red Series Dimmer switch. So, we will be adding in all the alternate firmware suggestions (ie: config milli-second time adjustment, instant on, etc).
Busted lol. So excited. I’ll have to review where this might work into my ecosystem better than a red dimmer…
Congrats!
Ha ha. I’m fixing that and the deleting this comment.
Oops!
giphy (7)
Haptic!!! Haptic!!! Haptic!!!
It would be cool if the light buttons were back lit (either around the perimeter or the icon) to make them easier to find in the dark. You get bonus points if the color is configurable. It might not be necessary, though, depending on the brightness of the other LEDs.
Perhaps this could be an opportunity to go beyond the current MLV dimming limitations.
Ok, I’ve heard the word before and I’ve looked it up online and still am confused. Can you give me a good example of haptic feedback? I feel so stupid asking lol.
So, rather than the LED Bar, you’d rather have the entire button backlit? Just asking for clarification, I’m impartial!
Yeah, so let’s get some thoughts on this. Currently MLV/MOSFET had to be chosen because it’s the only technology that would allow the following:
  • Use of Dumb switch or use of Aux switch
  • Use of Neutral and Non-Neutral
Since we’re trying to cater towards all users, the only choice we had was MOSFET. I wish I had raw data that showed me aux vs dumb and neutral vs non-neutral :frowning:
I’m glad you asked. I was too shy. lol. I was just going to ask @EricM_Inovelli
Can this be used as a second switch in a 3-way config with a red series dimmer?
Oh, I don’t see any LED bars on the dimmer buttons in the mockup so I thought there wasn’t room for them or something. If those buttons have the LED bars the back lighting doesn’t make much sense since the LED bars would be more consistent with all your other buttons. But if the LED bars aren’t there, I was thinking just the light bulb icons being back lit. Lighting up the whole button is probably a little too much compared to the the LED bars.
Haptic feedback is including a small motor/kicker/vibrator that makes a clunk or vibration that you can feel when you touch something. A good example is the faux iPhone 7/8 exit “buttons” (that you’ve probably never seen if you have Android phones). The “button” doesn’t actually move, but the haptic feedback makes it feel like it does.
An example from the HA arena is the Aeotec Wallmote Quad. It is a flat touchscreen, but uses haptic to tell the user that their press lasted long enough to have triggered a hold press. If Project Rock Out uses touch sensors for the scene buttons, haptic would be an important feature to add “feel” to a button press. If it uses actual buttons for the scenes, haptic could still be useful to give feedback when a “hold” has been sent…
It likely would be via association. The bottom two buttons would be able to associate to the Red Series Dimmer. Good reminder!
Ahhhh, got it – my fault. Yes, the current concept does not have the dimmer portion (bottom two buttons) lit up. We weren’t sure how to accomplish this.
We threw around the idea of wanting to create some sort of bar or indicator that the Dimmer portion was on and the bar would give some sort of level indication, but the problem we thought of was realistically, there was only room for maybe 1-2 LED bars and it wouldn’t really give a realistic view of the true value of the dimmer. Kind of similar to our Fan/Light switch – it shows a close value, but is not as accurate as the dimmer switch (LZW31-LZW31-SN).
What do you think here?
We talking when you’re typing on your phone (for me = Android) and you can feel the, “click” of the phone even though you know you’re not really clicking?
Yes, that is exactly what haptic is. It’s a piezo electric motor usually.
Not exactly. “Haptic” by definition is ANY kind of feedback you feel via sense of touch. A good old fashioned mechanical click is haptic. Its true that small motors are often used to create haptic feedback for touch screens that have no physical click, but a motor/kicker/vibrator is not required to be “haptic”
Wow! This is great.
Something that I know I’d be happy to see would be some form of a modular way to label the buttons. Although a guy can dream, I’m not saying to put a screen behind them or anything (pretty sure an old Z-Wave scene controller did that back in the day though), but even made-to-order buttons would be slick.
If the MLV is required for the non-neutral support, then this thought wasn’t very helpful … your hardware description up top didn’t mention that this little device was going to support the dumb switch/aux switch multi-way installation too.
