First of all, this is amazing. Exactly what I’d want in a couple locations in the house.
For feedback, I’d like to echo everything Chris said about Operation modes. That would be amazing. Something to think about for the future: for his mode 2, I’d almost want to see that in a separate, larger product. I’m envisioning a double wide decora panel as a sort of central control switch. It has 6 or 9 buttons, and works like Chris described. That functionality in a three button switch might be a little less intuitive when switching between triple and quadruple clicks to select a particular device you want to then control with the dimmer controls below. Still, a great option for power users, which I think is 90% of the forum.
Form factor: I think an LED bar that matches the existing Reds would be first choice like Chris said. A switch that blends in with existing switches would look the least jarring (which is super important), though you might lose a little functionality with the smaller LEDs to represent the scenes. I think it’s probably fine though.
Alternatively, I think kreene1987’s middle example is also great. It gives an led for the dimmer like existing switches (which can hopefully be lit up partially in the same way), while having configurable simple on off LEDs for the scene switches. Sharp, functional, though it doesn’t match existing switches, which might look a little jarring to people (and SOs) who want things to look tidy.
One thing I’d highlight though is the bottom buttons being two different buttons. If they’re instead designed as a small sideways rocker, it’s more intuitive that they are an on off switch/dimmer, rather than unrelated buttons. This matters with houseguests and less technically savvy family members. I think a modular button approach like has been mentioned could allow for two buttons rather than a rocker, but that should likely be aftermarket like the custom buttons (which are a great idea, btw).
All in all, this is an amazing product idea, especially with the ability to customize the buttons display. If you can figure out a way to make that not after market and still not look chintzy, I’d be one happy camper. Also, I imagine these won’t be as ubiquitous in the home as regular switches and dimmers, so a slightly more premium price would probably make sense, rather than losing functionality.
Along the lines of increased functionality motion is a good idea. I almost ordered the GE motion sensing zwave switches. However, given how cheap existing motion sensors are, and the fact that these switches likely won’t be put throughout the home, but only in certain locations, I’m not sure the added expense of a motion detector is worth it.
…though I’d still probably buy it. Looking forward to whatever you guys come up with!
