I am trying to set up Z-Wave association with one LZW31-SN dimmer switch and two LZW42 bulbs.
The switch is non-neutral and switches an overhead light fixture which contains dimmable (non-smart) bulbs. The LZW42 bulbs are installed in lamps located in the room. I am using a SmartThings v3 hub.
I would like to be able to press up/down on the switch to turn on/off overhead light and simultaneously send a z-wave message to turn on/off the bulbs.
I have created a group 2 association using the smartapp. It works when I press down to turn everything off. However, when I press up, only the overhead light (switch load) turns on. The bulbs remain off.
I found that if I set the switch’s “disable local control” option to “yes”, I can control the bulbs using the association as expected. However, in that case, I can no longer manually control the overhead light using the switch.
I’ve tinkered with this for awhile and I’m stumped. Any thoughts?
