Zigbee 2-1 Switch (On/Off & Dimmer) | Project New Horizon (Blue Series)
Project Update: Everything is still on track for a Q4 release. We are now working on the PCB and ensuring the manufacturer fully understands all the specs so there aren’t any surprises. I’m sure there still will be, but the best we can do is minimize it.
TLDR: No problem if you want a bad-a ZigBee switch. If you want a Matter switch, we are going to suggest you wait until mid-2022 to purchase as OTA is not available (you can still hard-wire update). OTA ZigBee is ok, however.
There is an, “issue” around our strategy, which needs to be called out. This switch was originally brought to life with two intentions – creating a ZigBee switch that would work with ZigBee bulbs (cough, cough… Hue… cough, cough) similar to our Z-Wave switch with the intentions of it also turning into a Matter switch once that protocol works as the chipset inside the switch will be convertible from ZigBee to Matter.
The issue lies in what we were originally told by SiLabs (and in fairness, the protocol and details were in its very infancy, so I’m not blaming anyone) in that the ZigBee firmware could easily be OTA’d to new Matter firmware as they share the same chip.
Unfortunately, from what we’re hearing, that isn’t true and the MG21 chipset cannot be OTA updated. It has to be updated via a wire. The MG24 can be OTA updated, but there isn’t an official release date on that and we’re currently being told mid-2022.
So, this leaves us in a bit of a pickle in the sense that we want to be on the cutting edge of this protocol, but updating to Matter will be a real pain for people if they purchase our initial batch of switches before the MG24 is implemented.
What we’re being told is that ZigBee hubs that update to Matter will be backwards compatible with ZigBee, so if you purchase this switch to use with your Hue hub or Amazon Echo Plus, when those hubs convert, they will still work with ZigBee. But again, if you want your Inovelli ZigBee switch to turn into Matter, then you will need to take apart the switch and upgrade it via hardwiring (we do plan on having a serial port on the PCB to do so).
Anyway, we figure that the initial purchasers of this switch are the hardcore users anyway and not mass market, so this shouldn’t impact too many people.
