Zigbee binding sometimes turns on at very low level
Hi folks! I have two identical VZM31-SN switches that I have set up with near-identical Zigbee bindings and one is behaving very oddly - sometimes a single tap to turn it on will set the light to a very low/dim level.
One switch is bound to a group containing two Philips Hue 6” ceiling lights, and has an aux switch. The other is bound to a group containing three Philips Hue 60W A19 bulbs. Both switches are configured and bound identically - smart switch, dimmer, double tap up/down enabled. In both cases I bound LevelControl and OnOff with endpoint 2 (I see endpoint 2 and 3, and no endpoint 1). The second switch has an aux switch connected and enabled.
The first switch behaves perfectly as I would expect. However, sometimes when I turn the second switch on with a single tap, it sets the level very low - usually around 36-37 but sometimes as low as 7-8. It’s not consistent, sometimes it works absolutely fine.
Anyone have any idea what’s going on here?
(please ignore the ‘vsd30k’ tag, for some reason the forum software is making me choose a product tag but only shows that one)
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
