It took me a while to figure out what to change to get the Adaptive Lightning add-on for Home Assistant to work with my Blue 2-1. It actually wasn’t much that needed to be changed.
I just needed to enable one setting that’s not part of the defaults:
detect_non_ha_changes: Detects and halts adaptations for non-light.turn_on state changes. Needs take_over_control enabled. Caution: Some lights might falsely indicate an ‘on’ state, which could result in lights turning on unexpectedly. Disable this feature if you encounter such issues.
I was having trouble before this was enabled that the lights would nearly always end up with manual control enabled. (Sometimes it seemed to work, though.)
I just wanted to share in case this helps anyone. I couldn’t seem to find anyone who posted something similar when I was troubleshooting.
Is your configuration dumb or smart bulbs? I’m working on this same problem and so far don’t have a solution to make the blue activate adaptive mode on the bound hue bulbs
If you’re using bound hue bulbs I would assume you’d also be adapting colour temp along with brightness? If so, you should be pointing the adaptive lighting at the bulbs, as the switch won’t have the ability to react to the color temp commands.
You’re spot on, the individual bulbs are easily working with both color and brightness by pointing directly at them. Now I want the blue switch to simply turn on the lights and AL to update the color and brightness.
I’ve found when the bulbs are off and start up behaviors are set to “on,” turning on the blue switch will turn on the lights like normal, and after some time the lights will update to AL. Ideally the adjustment would be immediate like when turning on the bulb from HA, but that solution isn’t obvious yet.
What’s your initial transition set to in your AL settings? And if they’re hue bulbs, they should be able to accept colour commands while off which should have the AL colour already being set before the light even turns on
Reading other comments, though, that I’ve still got it wrong since I have AL set up for the switch instead to the smart bulbs. I’ll change that and hopefully it still works properly.
Thanks, all, for the discussion and helping me realize that I didn’t have it quite right yet.
So here’s what I found while trying some stuff with smart bulbs last night:
Everything works pretty well when AL is set up with just the switch, but it does not adjust the color. The brightness adjustment happens about a second after the lights turn on. (This is most of what I want anyway which is why I didn’t really notice, but the temperature change would be nice, too.)
When AL adjusts the Zigbee group (light.coordinator_bedroom_light) it works pretty well and adjusts the brightness & color (still after about a second), but the switch doesn’t show the adjusted brightness level. This seems like the right way to do it if there’s also a way to get the switch to show the right brightness level.
When AL adjusts two smart bulbs & not the switch that controls them, it works about the same (though I think AL suggests not to do this to reduce messaging).
When AL adjusts both the switch and the group, they seem to compete at times for which one is right. The lights don’t stay adjusted to the requested state. This makes sense because AL is setting that one of the two is under manual control and then comes back to adjust the other that wasn’t changed manually. This configuration just get confusing to use.
I’m out of ideas of how to get this all tied together properly now. I’m guessing it’s easier without the binding, but would like to keep the binding.
Do your switches properly show the brightness value for a bound Zigbee light or light group?
Also, I’m not sure if you’re using ZHA, but if so, did you enable the global option Enable enhanced light color/temperature transition from an off-state in order to get adjustment to happen while the lights are off? (I have Hue bulbs & would love to get this all nicely tied together.)
Ok, I figured out something that will help for my situation. I’m using ZHA and have my switch bound to a group with two smart lights (Hue). To get Adaptive Lightning working, it seems that just binding to the Zigbee group (light.coordinator_bedroom_light) should be enough, but for whatever reason changing the brightness of that group (or the individual smart lights) doesn’t change the brightness of the switch they’re bound with.
So my work around:
Create a Home Assistant light group that includes the two smart lights and the smart switch. Have Adaptive Lightning adjust that instead.
I’m now getting proper temperature and brightness control via Adaptive Lightning. The LEDs on the Blue 2-1 are adjusting properly. And Adaptive Lightning uses this group to mark that manual control is enabled when the lights are adjusted via the switch or in Home Assistant.
I tried that as well, but as I noted above, my issue was the switch not showing the state change (brightness) when the bound lights were changed. Perhaps I have something set up wrong there.
Did you put the switch into the zigbee group it’s bound to? This is how I have it set up and al matches up with lights and switches that way (using z2m though)
I tried, but it didn’t seem to make a difference. I’ll try agin and report back.
I’m not sure if it matters, but for ZHA it only allows adding the switch as a device in the group on Endpoint 1 which it then lists as Identify, Light, And 41 more….
Hmm I use z2m so I’m not sure how zigbee groups work in zha but I would make sure all lights and switch are included in the group. Sorry I wish I could be more help
