Lzw30-sn association states not reflected in HA
These are the automations I use to work around the issue. Might be easier in node red. I created these a while ago before I added node red.
Load(primary)
Non load(secondary)
Thanks! Yeah to get around it I set up an automation to refresh the switch’s value if the state of the on/off sensor changes.
Has the fixed firmware for this problem been released yet?
Not yet. Latest firmware is 1.22. Hoping the next one will fix this.
Any update on the firmware fix for this?
I have this bug running v1.21 of the firmware. The release notes of v1.22 (dated 05/10/2021) don’t mention fixing this. Is a fix in the works?
I would not expect any firmware updates for the older LZW30/31 switches.
