3 and 4 gang boxes and common wire
I have a few three and four gang boxes I’m about to install new white series in. They have large bundles of commons. What’s the best way to address or fix as I’m not sure I can take the existing 5 commons and add 4 pig tails into one bundle.
That’s 9 wires, how would I wire nut this? Should I run each romex wire common to its switch and jump a common from switch to switch?
Thanks
You could add 1 wire and then jump switch to switch or use that wire to add 4 pigtails for the switches.
