Remove the traveler and the load conductors from the Inovelli. Leave the line, neutral and ground. Does the switch power up?
@Bry it does not
Got it. Remove the hot and neutral from the switch and test between the two using a meter. It should be 120VAC approx. The black is coming from a bundle, so I wouldn’t think there is an issue there, but test anyway.
If you’re getting 120VAC, my guess is that you smoked the switch miswiring it. You had the black on the 3-wire connected to what I believe was a a hot bundle, which means you had 120V on both the load terminal and the line terminal at the same time. Just a guess . . .
That was it. Switch was smoked. Swapped it out and all is good now. Your help was much appreciated, sir.
