3 Way Switch Red Series Lights toggling on after few seconds
Ah I see. I think for now I’m just going to do 1 LED and 1 incandescent since that seems to have fixed it, even if the wattage isnt great. I might come back and later do something like that or try find LEDs that might work without issues. Thanks both of you for your help!
I had a similar problem for a single pole-Neutral setup that was being used to control about 15 3W undercounter LEDs. The switch would turn on automatically a couple of seconds after it was turned off, except the switch didn’t recognize that it had turned itself on. I put in the bypass and it solved the problem.
Yeah that sounds like what I have
I had a similiar issue with a Red Series dimmer in a 3-way config with dumb switch and neutral setup. I replaced the LED bulb with a different brand and it’s been fine since.
