3Way Wiring 2in1 + Aux Guidance
I have a garage with 2 switches (3Way) for controlling 2 lights in the ceiling. I’m trying to replace these with a white series 2in1 and an Aux switch. I had trouble matching the existing wiring to one of the diagrams.
Below is near the entrance into the house:
This is on the opposite wall next to the entrance outside:
Any guidance appreciated.
-Randy
In case this helps someone else: the caped red, white, and black wires on the left side of the top picture were only junctioned here and were for a totally different circuit on a different breaker. I wish no one would ever do this, but that’s how it was done.
Otherwise this matched the no-neutral diagram with the power source coming into one of the light boxes. After wiring this up and turning it on, the switch continuously flashed cyan on the led bar and would not turn on/off the lights. Since this was a no-neutral setup and the lights in the sockets were unusual, I tried a more typical set of bulbs and the switches booted up and worked. There is still a lingering problem with the lights not turning off all the way off, but I expect that to be solved with a bypass or better/different bulbs.
