4-in-1 Motion Sensor Association to LZW30-SN via ZwaveJS
For the life of me, I cannot get my 4-in-1 inovelli zwave sensor associations to work with the Inovelli red series switch via zwavejs.
Both are in same security class: S2_Unauthenticated
Sensor group 2 (on off control) is associated to the switch node
Switch doesn’t turn on when motion is detected. What am I missing?
cc: @Eric_Inovelli
Tagging the other Eric (@EricM_Inovelli).
Do have parameter 14 set? Send Basic Set After PIR Trigger. Default behavior is disabled.
Edit: Fixed parameter number.
Ok…you definitely got me on the right track. Thank you! Don’t think there is a parameter 28, but I found documentation around parameter 14 on the 4-1 sensors that needed to be changed from 0 to 1. They are working now.
You are correct. I misread the parameter number. My device number is 28 and the parameter is 14.
Glad you got it figured out.
