Ran through all the diagrams first and ended up here. I’m trying to place a Blue Series Dimmer in a spot where I have 3 dumb switches controlling one light.
As far as I can tell by the wires, my current wiring setup is this:
Switch 1:
- Black wire on the common screw gets power from the breaker (Romex with black, white, and ground).
- Another black wire and gray wire are travelers going to Switch 2. (Romex with black and gray)
Switch 2:
- One Romex with red, gray, and a black wire in a wire nut:
- Red and gray wires are travelers to Switch 3.
- The black wire is wire-nutted and not connected to the switch.
- Another Romex with gray and black wires and a ground:
- Gray wire is a traveler from Switch 1.
- Black wire is the common wire carrying switched hot from Switch 1 to Switch 3.
Switch 3:
- Single Romex with red, gray, and black wires.
- Red and gray wires are travelers from Switch 2.
- Black wire on the common screw is the final switched hot wire going to the light fixture?
With this understanding, I’ve wired the Inovelli switch into the Switch 1 position with:
- Black Common → Line
- Back Traveler → Load
- Gray Traveler → Traveler
- White Neutral (bundle from box) → Neutral
- Ground → Ground
The switch works in this configuration, but toggling Switch 3 makes Switch 1 Inovelli lose power. Toggling Switch 2 then revives power, but then Incant touch Switch 2 or 3.
Am I incorrect about my assumptions for how this is wired?
Should I not wire the black traveler to the Inovelli load in this scenario?
Any help = greatly appreciated.
