I have a four way set up (2 three ways with a four way in the middle). I replaced the line side three way with a Blue Series and the other three way with an aux. Both work.
Am I able to use an inovelli aux for the 4 way in the middle? Inovelli’s wiring schematics only show a GE switch (not sure if that’s oversight or if an aux can’t actually be used).
If it can, attached are pics of the four way.
If I’m reading right, I should hook both reds into the transfer slots, connect the neutral to my set neutrals in the back of the box and then pigtail the blacks?
Presuming you have a neutral configuration line and load in separate boxes:
Yes, use the red to connect the Traveler on the Inovelli with the Traveler terminals on the Auxs.
Use the white to connect the neutrals on the Inovelli and Auxs.
Use the black to send the Load from the Inovelli through the middle switch to the far box with the load. In the middle box, bundle it to the black going to the far box. There, bundle it with the black load wire to the light. No need for pigtails.
