I’ve considered this approach before, but had a couple of reasons that make me hesitate:
Using Aux switches eliminates a zwave controller dependency. If the controller goes down the switches are still hardwired to each other and are able to communicate. With multiple switches, I would be uncomfortable with the risk of the controller going down and only the primary (load connected) switch working. Is there a way to wire the dimmers or switches together using the aux terminals to provide at least on/off and dimming if the controller goes down?
Association group limitations. I have a hallway in my house that has one set of lights controlled at 4 locations. And a second light controlled at 2 locations. It makes logical sense for those to be treated as a single load (both sets of lights come on together and match dimming). This works currently using associations because I have two dimmers and the rest are aux switches. If I swapped all of the aux switches to dimmers, I would have 6, which would exceed the limit of associations (5).
Curious if you have any suggestions on those.
