Hi folks, first time here.
I just had a Big Ass Fans Haiku Fan with light installed in place of an old fan and light.
Given the way the Haiku works, it needs constant power and everything is controlled via app or remote, so I’d like to figure out the best setup to make the switches at the wall function like they did with the old fan, or maybe even better. Could use some advice.
I have two switches at the main box, one was originally for the fan and one was for the light. The fan switch is now sending power to the Haiku (fan AND light) and the light switch isn’t doing anything.
The light switch is also a 3 way with a switch on the other side of the room.
Ideally I’d like to have a dimmer on the light in both of the 3 way locations. It’d also be cool to have a dimmer on the fan so I can control fan speed from the wall too.
I know the Red dimmers aren’t supposed to be used with fans, so that may be out of the question, unless I connect the load to a hot wire and leave it disconnected from the dimmer in the current fan switch spot?
I may have just answered my own question, but open to others’ thoughts on what you’d recommend for this setup.
