Main new feature is the ability to set the temperature change threshold in degrees F or degrees C based on location settings… It will convert it to the proper parameter value of 1-500 in .1 degrees C … It also shows appropriate range based on actual degrees…
More to come…
https://github.com/djdizzyd/Hubitat-Inovelli/blob/master/Drivers/inovelli-4-in-1-sensor.src/inovelli-4-in-1-sensor.groovy
Odd thing about these sensors… They don’t seem to change their behavior when mains powered… It still acts like a battery powered device… Have to wait for wakeup… and no repeater… I have dug into all the configuration parameters… and looked through all the command classes it supports, and can’t seem to find a way to change this behavior…
