Blue 2-1 bridged to Hue isn't turning off the lights
I am using Homeassistant 2024.12.4 with ZHA.
So I have gotten my 2-1 switch bridged with my Hue bulbs following the setup guide, there were some differences in the process as I’m using a later version of HomeAssistant to set this up. More specifically, “InovelliVZM31SNCluster 0xfc31 endpoint id 1” wasn’t found so I used “InovelliVZM31SNCluster 0xfc31 endpoint id 2” instead as it was the only option.
So the bulbs can be turned off in under the entry in “Nabu Casa SkyConnect v1.0”. However when I use the physical switch all I can do is turn them on and dim them. I can’t turn them off with the switch. How can I fix this?
