Blue 2 1 Matching dimmer settings
So I am trying to understand the dimmer settings in the switch’s configuration.
Right now is default of Min 1 and Max of 255.
My bulbs when I am trying to dim them down as soon as I get to 80 that’s almost off… anything underneath 70 the light bulb is fully off.
How Can I get the switch to behave correctly on the lower dimmer numbers IE 0 = off, not 70 = off.
Start with the default settings. Dim all the way up and if the performance is fine at the brightest setting, leave that alone. Then start dimming down gradually until you get to the point that the bulb goes out. Then set the minimum level at a couple percent over that value. This will remap the percentage range so that a displayed 1% should have the bulb barely illuminated.
