I have a probably peculiar question/enhancement request. I would like the switch to remember the last brightness used, but only for a few hours/based on room occupancy, which requires a way to set automatically stored last used brightness.
Going through parameters available I see there is Parameter 13 - Default Level - Local & Parameter 14 - Default Level - Remote. However, there doesn’t seem to be a way to set/reset “last brightness” when params 13 & 14 are set to 255. I tried the following sequence while using Z2M:
- set
defaultLevelRemote - set
brightnessto 250 - turn off
- turn on => as expected turns on at 250
- turn off
- set
defaultLevelRemoteto 50 - set
defaultLevelRemoteto 255 - turn on
I was hoping the switch will turn on at 50, but it’s apparently smarter (ha!) and remembers the brightness of 250 separately. Is there a way to reset “last used brightness” when the light is off?
