Blue 2.1 single button press - detect in Home Asisstant
Hello. I’ve a Blue 2.1 installed and have succesfully integrated into Home Assistant.
I’ve an automation that controls the on/off state without issue.
However, I’m having zero luck in detecting a physical toggle of the switch itself.
My end state is to detect when the switch is physically toggled off (with a single click), and run some other automations.
Any guidance would be greatly appreciated.
Are you using ZHA or Z2M with Home Assistant?
If ZHA, I believe you’d just need to use a device trigger for “Down press” and that should do what you’re looking for?
ZHA - and you are correct!
Thanks for the nudge!
