I’m seeing some weird behavior in my blue 2-1’s recently: Whenever I change the state locally by pressing the paddle up or down, the state isn’t reflected in zigbee2mqtt; when I open the “exposes” tab on the device and hit refresh on the power state however, it does update to the correct value.
I switched logging in zigbee2mqtt to debug and took all the messages that mention the switch when I hit the up paddle and when I hit the down paddle; note how "state": "OFF" keeps showing up in active power reports, and there’s no apparent state transition being reported:
Nov 26 11:12:51 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:12:51: Received Zigbee message from 'LTS-BA-3-office main', type 'raw', cluster 'manuSpecificInovelliVZM31SN', data '{"data":[21,47,18,96,0,2,0],"type":"Buffer"}' from endpoint 2 with groupID 0
Nov 26 11:12:51 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:12:51: Received Zigbee message from 'LTS-BA-3-office main', type 'raw', cluster 'manuSpecificInovelliVZM31SN', data '{"data":[21,47,18,96,0,2,0],"type":"Buffer"}' from endpoint 2 with groupID 0
Nov 26 11:12:51 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"up_single","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:51.275Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":0,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:51 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"up_single","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:51.275Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":0,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:51 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:51.275Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":0,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:51 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:51.275Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":0,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:51 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main/action', payload 'up_single'
Nov 26 11:12:51 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:51: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main/action', payload 'up_single'
Nov 26 11:12:56 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:12:56: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1547}' from endpoint 1 with groupID 0
Nov 26 11:12:56 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:12:56: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1547}' from endpoint 1 with groupID 0
Nov 26 11:12:56 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:56: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:56.006Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":25,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.7,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:56 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:56: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:56.006Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":25,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.7,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:56 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:56: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:56.017Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.7,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:56 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:56: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:56.017Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.7,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:57 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:12:57: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1545}' from endpoint 1 with groupID 0
Nov 26 11:12:57 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:12:57: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1545}' from endpoint 1 with groupID 0
Nov 26 11:12:57 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:57: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:57.985Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:57 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:57: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:57.985Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:12:58: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1545}' from endpoint 1 with groupID 0
Nov 26 11:12:58 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:12:58: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":1545}' from endpoint 1 with groupID 0
Nov 26 11:12:58 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:57.999Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":25,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:57.999Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":25,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:58.086Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:58.086Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:58.103Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:12:58 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:12:58: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":null,"activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:12:58.103Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:13:01 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:13:01: Received Zigbee message from 'LTS-BA-3-office main', type 'raw', cluster 'manuSpecificInovelliVZM31SN', data '{"data":[21,47,18,103,0,1,0],"type":"Buffer"}' from endpoint 2 with groupID 0
Nov 26 11:13:01 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:13:01: Received Zigbee message from 'LTS-BA-3-office main', type 'raw', cluster 'manuSpecificInovelliVZM31SN', data '{"data":[21,47,18,103,0,1,0],"type":"Buffer"}' from endpoint 2 with groupID 0
Nov 26 11:13:01 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"down_single","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:13:01.686Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:13:01 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"down_single","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:13:01.686Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:13:01 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:13:01.686Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:13:01 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main', payload '{"action":"","activeEnergyReports":null,"activePowerReports":null,"autoTimerOff":null,"brightness":116,"buttonDelay":null,"defaultLed1ColorWhenOff":null,"defaultLed1ColorWhenOn":null,"defaultLed1IntensityWhenOff":null,"defaultLed1IntensityWhenOn":null,"defaultLed2ColorWhenOff":null,"defaultLed2ColorWhenOn":null,"defaultLed2IntensityWhenOff":null,"defaultLed2IntensityWhenOn":null,"defaultLed3ColorWhenOff":null,"defaultLed3ColorWhenOn":null,"defaultLed3IntensityWhenOff":null,"defaultLed3IntensityWhenOn":null,"defaultLed4ColorWhenOff":null,"defaultLed4ColorWhenOn":null,"defaultLed4IntensityWhenOff":null,"defaultLed4IntensityWhenOn":null,"defaultLed5ColorWhenOff":null,"defaultLed5ColorWhenOn":null,"defaultLed5IntensityWhenOff":null,"defaultLed5IntensityWhenOn":null,"defaultLed6ColorWhenOff":null,"defaultLed6ColorWhenOn":null,"defaultLed6IntensityWhenOff":null,"defaultLed6IntensityWhenOn":null,"defaultLed7ColorWhenOff":null,"defaultLed7ColorWhenOn":null,"defaultLed7IntensityWhenOff":null,"defaultLed7IntensityWhenOn":null,"defaultLevelLocal":255,"defaultLevelRemote":141,"dimmingSpeedDownLocal":null,"dimmingSpeedDownRemote":null,"dimmingSpeedUpLocal":null,"dimmingSpeedUpRemote":null,"doubleTapUpForFullBrightness":null,"energy":5.27,"firmwareUpdateInProgressIndicator":null,"invertSwitch":null,"last_seen":"2022-11-26T16:13:01.686Z","ledColorWhenOff":null,"ledColorWhenOn":null,"ledIntensityWhenOff":null,"ledIntensityWhenOn":null,"linkquality":29,"loadLevelIndicatorTimeout":null,"localProtection":null,"maximumLevel":null,"minimumLevel":null,"onOffLedMode":null,"outputMode":null,"periodicPowerAndEnergyReports":null,"power":154.5,"powerType":null,"rampRateOffToOnLocal":null,"rampRateOffToOnRemote":null,"rampRateOnToOffLocal":null,"rampRateOnToOffRemote":null,"relayClick":null,"remoteProtection":null,"smartBulbMode":null,"state":"OFF","stateAfterPowerRestored":null,"switchType":null,"update":{"state":"idle"},"update_available":true}'
Nov 26 11:13:01 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main/action', payload 'down_single'
Nov 26 11:13:01 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:info 2022-11-26 11:13:01: MQTT publish: topic 'zigbee2mqtt/LTS-BA-3-office main/action', payload 'down_single'
Nov 26 11:13:07 bonnetmaker zigbee2mqtt[598255]: Zigbee2MQTT:debug 2022-11-26 11:13:07: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":0}' from endpoint 1 with groupID 0
Nov 26 11:13:07 bonnetmaker podman-zigbee2mqtt-start[597802]: Zigbee2MQTT:debug 2022-11-26 11:13:07: Received Zigbee message from 'LTS-BA-3-office main', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":0}' from endpoint 1 with groupID 0
This switch is on firmware 2.08 (though z2m OTA view shows 2.07), and zigbee2mqtt is running in a docker container at release 1.28.2. Switch is in a neutral single-pole setup, configured to be a dimmer - connected to four incandescent bulbs, if that matters.
