I have about 20 blue series 2 in 1 dimmers. I update them in Hubitat and they say they complete 100% however in one area they show as updated but in another they still show as the old firmware. How do I know which one to believe ?
Try changing your device driver to “device“, going back to the commands page and clicking on all of the buttons that clear out data and state. Then restore the Inovelli device driver and click on “configure“ on the command page. This should clear out old states in Hubitat.
Not sure if this is the school solution (old military term), but reboot the hub.
I did a test update from 2.18 to 3.04. After configuring all and initializing, and power cycling the switch, the device commands page still reflected 2.18. I bounced the hub and the device commands page now reflects 3.04.
In other words, I rebooted the hub and the proper firmware level started showing. This appears to be a refresh issue in Hubitat. According to your logs, the reboot completed, but I think Hubitat is not showing the newly updated firmware level properly. In my case, rebooting the hub fixed that.
This is starting to sound like the update bug (which affects systems beyond just Hubitat) that requires using a harness to get around…. I had to do that for all my Blues a while ago to get to 2.18 (thankfully, the 3.04 update went fine OTA for me on all Blues, so hopefully I never have to see that harness again).
Contact Inovelli support - they can coordinate getting a harness to you.
No idea, bought them when they first came out, and dont really want to go around pulling them all out to look at them. Is there someone else I can find that ?
Then it’s almost certainly that update bug. But reach out to support - they can probably help confirm, and help arrange getting the fix to you.
If you do need to confirm the date codes, I think that sticker is on the front mounting plate, so hopefully the worst you’d have to do is pop of the switches’ cover plates to check.
Yeah, this issue only effects switches from the first batch (date code starts with 22). So it definitely sounds like that problem. Reach out to [email protected] and they’ll be able to get you sorted with a cabled flashing tool.
You will have to pop the covers off to get them cabled though.
Do you mean that you have seven that are in the bad batch category? Inovelli offered replacements for those when the issue was first identified, but that was a couple of years ago. I have no idea what they’re doing now. You would have to contact support to inquire.
