Blue canopy: default speed when turning on fan
I just installed the blue canopy module (VZM36). I have integrated it with Home Assistant. When I turn on the fan via HA UI, the speed is always medium, however I want low speed. How can I configure the module to turn on at low speed? Thanks!
I found a workaround. I created a Home Assistant automation that sets the fan speed to low whenever the fan is turned on:
- id: 'ceilingfanlow'
  alias: Turn on ceiling fan to low
  triggers:
    - trigger: state
      entity_id: fan.inovelli_vzm36_fan
      to: 'on'
  actions:
    - action: fan.set_percentage
      target:
      data:
        percentage: 33
