Blue Dimmer Zigbee Bindings: Detach EP2 from EP1
I have a VZM31-SN whose load is part of a Zigbee group with another right next to it. It’s redundant to have two switches in the same gang box which control the same group of lights, so I’d like to bind its EP2 to another group it’s not a part of. Unfortunately, this doesn’t quite work as expected, because the EP2 switch still controls the state of the local EP1 relay.
Activating smart bulb mode doesn’t do what I want, though it’s similar; the problem is that it forces the relay on and I need it to still be able to be controlled. I don’t want to add a smart bulb either, both because it’s one of those “lifetime” LED fixtures without a bulb and on principle.
Activating local protection mode doesn’t do what I want either; firstly because while the physical buttons do still emit events I can build Home Assistant automations off of, it’s decidedly non-trivial to emulate the full functionality of a dimmer switch that way, and secondly because I’ve got an automation which needs to be able to turn on local protection mode temporarily to repurpose the switch buttons.
What I think I need is a new option to detach the automatic internal “binding” from EP2 (the switch) to EP1 (the relay). This would also allow me to “swap” two switches in the same gang box whose order makes no sense without rewiring, in a controller-less, sell-it-with-the-house-to-a-tech-illiterate manner, which I’d really like to be able to do.
(If there’s something I’ve missed and this is possible already, please let me know!)
Edit: I initially specified the wrong model number – VZM36 instead of VZM31-SN – for the device I’m talking about. (Whoops.)
Looks like I’m not the only one looking for this capability: https://www.reddit.com/r/homeassistant/s/6a9QEFs2cJ
Yeah, you’re definitely not alone. I requested this back in 2024 as well. It’s on Inovelli’s private github for feature requests but they haven’t gotten to it yet. I’ll give it a bump and show that there’s more interest.
New Inovelli Blue customer here. I’d love to see this implemented as well. Transitioning from Zwave to Zigbee largely so I can take advantage of binding to Zigbee smart bulbs, but still have a few places where I have a dumb bulb on the switch load but want to bind a smart bulb connected elsewhere.
Moved some switches around today; still looking for this! As is, I have to have my HA instance running so automations + local protection can emulate it. Would very much like that to change before I eventually sell the house.
