I have been using the Blue Fan switch in my living room, and am considering putting one in the bedrooms. One thing that I don’t like is the brightness of the LED since it’s always on when the fan is on. Any suggestions on how to configure the switch so that It isn’t so bright but yet I still can see what speed the fan is set to when I am trying to adjust it? I am using Home Assistant Yellow with ZHA and don’t see any brightness options in the various settings for the switch.
If you go to the device page > 3 vertical dots that are to the right of Reconfigure > Manage Zigbee device > Change to the Inovelli Cluster on Endpoint 1 > led_intensity_when_on (id: 0x0061) is the parameter you’re looking for. Play around with the brightness level to find what works for you from there by setting the value and hitting write attribute ![]()
(0-100 as a range from off to 100% brightness)
I know this post is old, but this has been my home assistant solution. It turns the brightness of the LED up and down based on sunrise / sunset. If I turn any of the lights on in the bedroom at night, the LED goes back to normal day values, and when the light is turned off, back to night values. Works great and minimizes excess light at night.
alias: Switch LED Intensity - Master Bedroom Fan Switch description: Changes fan switch ON LED intensity for sleeping. triggers: - entity_id: light.master_bedroom_lights trigger: state - event: sunrise trigger: sun - event: sunset trigger: sun conditions: [] actions: - choose: - conditions: - condition: sun before: sunset after: sunrise sequence: - action: number.set_value target: entity_id: number.master_bedroom_ceiling_fan_default_all_led_on_brightness data: value: 33 - conditions: - condition: sun before: sunrise after: sunset - condition: and conditions: - condition: state entity_id: light.master_bedroom_lights state: "off" sequence: - action: number.set_value target: entity_id: number.master_bedroom_ceiling_fan_default_all_led_on_brightness data: value: 3 - conditions: - condition: sun before: sunrise after: sunset - condition: and conditions: - condition: state entity_id: light.master_bedroom_lights state: "on" sequence: - action: number.set_value target: entity_id: number.master_bedroom_ceiling_fan_default_all_led_on_brightness data: value: 33 mode: single
