Blue, Hubitat Generic Zigbee outlet
hi!
I’m trying to figure out how to have my Inovelli Blue Switch control a Generic Zigbee Outlet
I bought - Amazon.com
Is there any recommendation for a set-up with a single switch controlling it or two or more.
Michael
I would use the Button Controller app (or Basic Button Controller) in Hubitat to assign whatever you want to do with the outlet to whatever button tap/hold/multi-tap on the Blue.
I use Button Controller to assign all sorts of different additional duties to my Blues (or primary duties in the case of my no-load Blues) – it works like a champ.
Be aware that Inovelli uses a custom button mapping for the Blues – you’ll need to use this to program in your setup to Button Controller (or Rule Machine etc):
Thanks.
Was trying the dimmer button controller and couldn’t figure out why the plugs weren’t showing up.
One other one that i need help with
Recommendation for a virtual 3 way set-up
Have a blue connected to a load and want another blue to also control the load. Is there a recommended way? Should I zig be bind them?
Thanks
