Hi.
Here’s my setup:
Innovelli Blue Dimmer, Connected in a non-neutral 2-wire setup, which is then connected to a circuit which goes to my central light which has 3 Phillips Hue 800 lumen lights on the circuit.
Switch is set to smart bulb mode.
The issue: Whenever I turn off the hue lights via the hue app, the switch starts fashing a turquoise light and won’t work again until I reset the switch (via the bottom left pull tab).
This seems to only happen when the light directly on the switch is turned on. Seems like the switch isn’t getting enough power.
I tried the aotec bypass, and wired it to the ceiling lamp that’s connected to the same circuit as shown:
So the bypass is connected to the two wires that the light fixture also connect to.
Seems like this should work, but it appears to have no affect.
Wondering what I may be doing wrong.
