Blue Series 2-1 Firmware Changelog | VZM31-SN
Fixed LED notification behavior that did not operate as expected.
Are there more details on this?
I have a VZM31-SN directly bound to the VZM-36 fan canopy module. It used to work where if I sent a command directly to the canopy controller light or fan, that the LED on the switch would automatically update to on off, or the percent dimmed. This was without groups - just a pair of direct binds from the switch to the fan module, and LED sync just worked. It was honestly very impressive when I first set it up.
Now, I can’t get the LED to sync. I suspect upgrading to 3.04 introduced this, but it’s not a common interaction for us so it’s been a while. I could reconfigure things to use groups instead, but I’d rather not if this is fixed in 3.06.
I think this is the issue mentioned at VZM31 to VZM36 Binding Issue.
(Using zigbee2mqtt, though I doubt it matters in this case)
