I believe there is a issue with the firmware beta.
In Home assistant (ZigBee2MQTT), if you set the stay areas (in my case Area 1), and apply them, under STAY AREA, go back in and it swaps the Width min and Width max numbers. Changed 3 times, and it swaps the numbers when you go back in to the settings page. I cleared the stay areas, and tried again, same thing happens. I am unsure if the original 1.00 does this, as all the mmWave are running the beta.
It did fix the switch not working after changing the “LoadLevelIndicatorTimeout” from 1.00 however.
