I’m not sure what is happening and was hoping that someone can help.
I have had a blue switch controlling three LED coach lights outside my garage for a few months with no issues. During the house construction, I had it wired in case I wanted to add another coach light, and decided to add on the new coach light this weekend. This is when I started having issues. After wiring everything up, the switch no longer worked.
After doing a lot of troubleshooting, I found out that I had driven a screw through the wires powering the new coach light. I fixed this and wired everything back, but the switch still didn’t work. I figured that I had likely blown the switch, so put in a new Inovelli switch and it still didn’t work.
I then wired the hot to the load to check the circuit and all of the lights powered on correctly. I also tried an enbrighten smart dimmer and it also worked, somewhat. Using the enbrighten switch, when it was turned on, the lights strobed very quickly.
Doing some more troubleshooting, I found a few weird things- the Inovelli switch powered on when the load and the line were switched. When wired like this, it acted like it worked correctly, with the LED going bright when the top button was pushed and going dim when the bottom button was pushed. However, the lights remained off in both cases. When wired like this, I tried factory resetting the switch by holding in the top button and the config button for 20 seconds, until the LED turned red. Unfortunately, this didn’t change anything. When wired like this, I measure 122VAC between the load and neutral or ground, 1.97VAC between line and neutral/ground when off, and 3.00VAC between line and neutral/ground when off.
When wired correctly, I measure 122VAC between line and neutral/ground and 1.04VAC between load and neutral/ground and the LED doesn’t light up and the switch appears inoperable. I tried it without the neutral connected with the same result.
I also switched back and forth between the new and old Inovelli switches with the same response. In each instance, I’ve checked all of the connections to make sure that are secure. To make things more confusing (at least for me), the lights work fine with a dumb switch.
I’d appreciate any help. Thanks!
