Hello I currently have the Zigbee 2 and 1 switch and the zigbee fan canopy. Everything is on the latest version but Im really struggling to get my switch to be able to control the fan and light separately.
Currently I am using a zigbee binding to connect the switch to the canopy, I’ve set param 120 to 2, 130 to 1 (even though this doesnt work).
I have also tried setting 120 to 0 and 130 to 1 and that also doesnt work. Is there something else Im supposed to do?
Is this the process you followed to bind the switch to the canopy? I’m guessing if you’re having a button press control the whole canopy module, you just bound the switch directly to the module instead of the separate endpoints for the fan and light?
I am currently bind the whole switch. I tried following the guide you just linked but I dont have those options. I am on firmware 0x01020212 for the switch
If you bind the whole switch, it’s going to be all or nothing. So in order to do the group binding and separate control, note that you’ll need to unbind those.
When you installed the VZM31-SN, was it already at that firmware level or have you upgraded it since? You may have to remove and re-add it to ZHA in order to get Endpoint 3 to show up there and then it should match up process wise.
