Buzzing from switch
I have the scene + notification on/off switches. I have purchased 5 of them and have 28 of the dimmers on order. One of my switch in a 3 way configuration with 2 850lumen led lights causes a horrible buzzing at the switch when turned on. All 4 others work as intended. Ideas? I’d rather not switch switches as I’ve spent quite a few hours with the 3 way.
Thanks
Hey @DGRESBACK - sorry about the buzzing! Let’s see if we can figure it out.
Are you able to swap out the bulbs at all to see if that helps?
its the switch. I changed the switch and the new one in the same position doesn’t make the noise.
Got it, let’s get it swapped out for you then.
@Courtney_Inovelli can shoot you a PM and get your info so we can get it swapped out for you.
Apologies for the inconvenience.
