I noticed Aartech Canada has two types of LED stabilizers that may be a good option for anyone that needs them in Canada. I have not tested nor had a need for one of these yet, as I’ve only installed one dimmer so far (just placed an order for 20 more).
There is a yellow and blue version and the description notes it is impossible to know which one will help (in some cases, both), so they offer a 4 pack (2 of each) to test with. Might be worth a shot if you are having flickering or On when Off issue. They can also be bought individually (more expensive).
Check their website for Stabilizer. The sample pack is called LED Dimming Stabilizer 120V Sampler Pack 2 Yellow 2 Blue (1 Per Customer)
@Eric_Inovelli I think you would get a good bit of Canadian interest through Aartech Canada, I would reach out to them if you have not already.
…Donovan
