Color-matching plates to go with paddles
I’d like Inovelli to consider selling the wall plates in addition to the paddles. Lutron seems pretty proud of their plates, asking anywhere from $9-15 for a 1-gang plate, which seems crazy for some colored plastic - it’d be nice if there was an option to purchase plates along side the paddles on the Inovelli store IMO.
Apologies if this is in the wrong section - wasn’t sure exactly where such a request would fit!
They’re like $0.75 at Home Depot.
The Lutron Claro plates, which is what the inovelli switches are designed to match with, are close to $10 USD at the local Home Depot here.
Exactly what I’ve experienced as well - for example, if you want the red plate, single gang is over $12USD :open_mouth:
Home Depot - Lutron Signal Red Plate
@Jonesie if you could share where you’re seeing them so cheaply, I couldn’t be happier to be wrong about this lol
Not sure if it helps, but I’ve been using the Enerlites screwless plates found on Amazon. The whites may be a tiny bit brighter than Inovelli’s plastic, but you really, really have to look closely.
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
