I’ve currently got a dumb switch that controls an outlet in my bedroom. I want to have dimmable lights in the room, and I know you shouldn’t control an outlet using a dimmer switch.
Can I take the wiring in the outlet box and change it so the outlet is non-switched, on 24/7, then connect the two wire running to the switch box to the Line and Neutral in the outlet box so that the wiring that is in the switch box can be used to power the smart switch. The smart switch wouldn’t have a load wire, as it wouldn’t be physically controlling anything.
The smart switch could then control smart bulbs in the room to allow dimming, and potentially also be used to control a relay for the closet light that currently has a pull chain, and possibly other scenes I come up with.
Basically this is just trying to get around having to use a battery powered switch by reusing some existing wiring as a power source.
