Is it possible to change the current dim level indicator to something other than blue?
Yes, parameter 13.
https://inovelli.com/wp-content/uploads/LZW31-SN/LZW31-SN-Dimmer-Manual.pdf
Got myself a dimmer so now I get to mess with this stuff! Is it possible to make the indictator white? Everything I see is single value RGB and I’m not seeing a sliver of white on the color picker tool.
With the current firmware it is not possible to get white from the indicator. Parameter 16 contains the hue, but you would also need a saturation value in order to get white. I think it would be a great feature request though.
If you havent seen it already, one of our forum posters created an incredible tool for calculating the LED settings:
