Default Level Parameters not Saving
Hey all,
So I’m working on some automations invlovling Z-Wave Configuration Parameters, and I noticed something weird with the Default Level parameter that I’m hoping for some insight on. The documentation says the range is 0-100, but when I set it to 100, the Z-Wave log reports back that the value didn’t change. If I set it to 99, then it changes to 99.
Is there an error in the documenation and 99 is the maximum I can set this to?
I might be mistaken and @EricM_Inovelli should confirm, but I think the Z-wave level only goes to 99.
That is correct. 99 is the max value for this parameter.
Got it. Thanks.
It might be worth updating Eric’s documentation linked in my first post and the Open-Zwave config (which gets displayed in Home Assistant) because they both show that it goes to 100.
@Eric_Inovelli - Maybe some redline updates for documentation when you are chilling in the office with nothing to do?
@tyfosho @harjms The document has been updated and open-zwave merged all the changes to our config files.
