Dimmer Syncing with bound lights
Curious if anyone knows how to sync the dimming rates on bound zigbee lights with the blue series switches so that they start and stop dimming all together? As is right now my lights turn on/off much faster than my switches in the bound state. I’m using zigbee2mqtt on home assistant
Sounds like your dimmer is transitioning off while your bulbs are just turning off. You could adjust the transition time on your dimmer
Yeah, was wondering if ultimately each had to be individually adjusted or if there was some way to adjust the dimming rate of all grouped devices. Guess the answer is that they each individually have to be adjusted to remain in sync. Thanks!
